Generating "Series" of Case Statements to Manipulate Waveform
Hi All,
I'm trying to find a way generate an 'unknown' number series of case statements, the number of which will be determined at program start (the minimum number of which is zero, and the maximum number is not known). Assuming we are given the required number of case statements as an integer n, I would like to do the following:
1) A waveform signal feeds either: the first case statement (if there is more than one or more), or the waveform chart if the number of case statements is zero.
2) If another case statement is required, create it and feed in the output from the previous case statement. If there are no more case statements requried, feed the output from the last case statement to the waveform chart.
3) Repeat 2 until there are no more case statements required (# of case statements = n)
A simplified visual representation of what I am talking about for two cases is in the following image:
(For those wondering: The command values will be read from an array of size n.)
I realize the system will not be visible this way. I'm just hoping there is way to generate this system using a loop.
Any help is greatly appreciated. Please let me know if you have an idea but need clarification.
Stefan
Message 1 of 9
(1,761 Views)
Search for ...
State Machine
and
Shift Register
The State machine will let you control the work done on the data and the Shift Register will store your results of one step to be acted on by the next step.
Ben
Message 2 of 9
(1,754 Views)
You need to explain your task better, because you are basically asking for a program that writes its self.
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 3 of 9
(1,752 Views)
Spoiler
From what I learned from the Hamster Theory of RSX the self generated code would wake up and tell itself to go to sleep. Lather rinse repeat.
Smiley-wink
Ben
Message 4 of 9
(1,745 Views)
Accepted by stefan2h
Do you have a finite set of "commands"? Create a case structure containing one case per command (and a default case wired across) and place it inside a FOR loop. Wire the data via a shift regsiter across the case structure.
Create an array of commands and autoindex on the left loop boundary and wire to the case selector.
If the array of commands is empty, the data will exit the loop unchanged. Else it will process the data with all commands in the order they exist in the array. The array can even have duplicate elements, causing application of the algorithm multiple times in a row.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 5 of 9
(1,722 Views)
Hi altenbach,
I do have a finite set of commands. I should have explained this more clearly. This sounds like exactly what I want to do, I just didn't know it. I will look into your suggestion more closely tomorrow when I am back at my workstation.
Thank you very much for taking the time to write such a detailed reply.
Stefan
Message 6 of 9
(1,692 Views)
Hi again altenbach,
Here is my implementation for others interested. In my case I actually have a 2D array. Each row is a new command AND set of parameters that indicate magnitude, start and end times of the waveform modifications I want to make. To take care of the start and end times I used a nested case statement. This can be seen in the attached vi.
Thank you again.
Stefan
Message 7 of 9
(1,668 Views)
Here are a couple of tips.
1.  Index Array is resizable.  Just drag down the bottom border.  Wire i into the top of the first element.  Wire 0 into the bottom of the first element.  Now you'll get i,0  i,1  i,2  i,3  like you do now without splitting the array wire, without needing 3 more index arrays, and without needing the extra wires and constants for the index inputs.
2.  Rather than a 2-D string array, I'd use a 1-D array of clusters.  Each element of the cluster could be a string, a double and a pair of U64's.  That way you can be sure you have the proper data entered into each one  (what would happen if you accidentally had a character in string field that was being converted to a number?).
3.  Instead of adding one in the timed loop, use the increment function.  I would actually merge the display loop with the tick count loop.
Message 8 of 9
(1,661 Views)
Seems a bit convoluted.
  • The inner loop should be a FOR loop because you know the number of iterations before the loop starts.
  • You can autoindex on the string array, giving you one row per iteration
  • Index array is resizeable, only one instance needed.
  • (taking the array size belongs before the loop, because it does not change during the loop, but with a FOR loop you don't need it anyway).
  • Most of your indicators have the wrong representation (see all these corcion dots?)
  • All that "tick count" stuff with three parallel loops seems very comvoluted. What is it supposed to do?
For example the upper left of your inner loop could be simplified as follows:
Message 9 of 9
(1,659 Views)
