Generating PWM 25kHz with PXIe-6361
Hello. I am just starting with PXIe and LabVIEW tests on it. I need to generate PWM signal to control a motor , 25kHz , from 0 to 100% duty cycle. First of all, I don't know which pin I can use on PXIe-6361 and second, how to implement it in  a LabVIEW. Thank you in advance for your help.
(1,099 Views)
This article helps you get started - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1P0CAI&l=en-US
Santhosh
Soliton Technologies
(1,054 Views)
