11-20-2020 06:06 AM
I am fairly new to labview. I have been trying to configure an analog output for sinusoidal signal generation at 200kHz for my application generating continuously for a user defined time. I can manage this for signals up to 100kHz sampling at 1Mhz, which works okay. When I try to increase this to 200kHz at various sampling frequencies, I get an error.
If I do a similar application of 200kHz in for finite duration (i.e. 10ms), It works. I am sure there is something silly that I am missing but I am yet to fix this issue. Any thoughts?
This specification of single channel AO generation is 2.86MSa/s which I am not exceeding. I do however notice, that if I go over 1.25MSa/S (the conditions for 4 AO used simultaneously) I also get an error, but I am only configuring and using 1 channel. Weird.
I have attached the VI example where it does not work.
(p.s. I have also tried removing the duration to stop the loop incase this is the issue, but no luck).
11-23-2020 05:05 AM - edited 11-23-2020 05:06 AM
Hi Jenks,
Your AO task is set to 400kHz samplerate.
Your SimulateSignal ExpressVI is set to create a waveform of samplerate 2MHz with a sine at 200kHz of just 10 samples. Later on you remove any waveform timing by converting into a 1D array of samples.
Which error do you get? Where does the error occur?
My recommendation: get all those numbers clear. I also recommend to create waveforms of more than just 10 samples…
