06-06-2007 08:46 AM
06-11-2007 11:45 AM
Daniel,
It sounds like you are trying to generate digital pulses using your DAQ board. The counter output is designed to be a digital signal. That is, the amplitude of the signal is either 0 V or +5V. Therefore, the amplitude cannot be controlled.
However, there are some great examples in the LabVIEW Example Finder that will help you implement your two options.
Access the Example Finder by navigating to Help >> Find Examples... Then go to Hardware Input and Output >> DAQmx >> Generating Digital Pulses. There are several examples there which you can check out to get you started. The most interesting to you are likely Gen Dig Pulse Train-Continuous.vi and Gen Dig Pulse.vi.
I hope this gets you started in the right direction.
Stephen Meserve
Applications Engineering
