Generate a viberation signal in LabVIEW
Hello
I have been trying to generate a signal which is identical to vibration signal captured from a motor.
The tasks are  -
Create a vi to generate a vibration signal and store in for of .dat file.
Create another vi that could read the previously created .dat file and perform FFT, Order analysis.
I am unable to do this . Can anybody help ?
Nishant
(2,668 Views)
Do you know LabVIEW?  Are you interested in learning LabVIEW and "doing it yourself"?  Do you need help hiring a LabVIEW developer to do this for you?
If you are interested in learning LabVIEW so you can solve this problem yourself, you can start with the Getting Started with LabVIEW links on the first page of this Forum.  Once you have some experience and want to try to write some LabVIEW code for your problem, feel free to return here, post your code (attach the VI) and we'll help you to learn.
(2,640 Views)
