I am using the NI cDAQ-9172 (with output module NI 9472 and input module (9421). I am trying to generate a pulse, run it through a system (just a resistor at this point) and then read it back into labview. I am able to generate the pulse with no problem, but anytime I try to read it I get an error regarding the clock. Any suggestions?
Looks like i figured it out. I had the clock said as hardware timed, but my hardware was wired wrong. After I corrected the wiring it worked, so that must have been the problem.
