Hi All,
I want to generate the eight different 5V pulses with 95% duty cycle & each having different phase shift with respect to my input reference using PXI-6251.
The input is 400Hz (+/-2Hz tolerace) square wave whose rising edge is my reference for generating the output "train of pulses".
Each output should have seperate phse shift control.
As 6251 has only 2 counters & hance I require your help on the same.I also have one PXI-6509 DIO card, but will it be of any help??
Thaks in advance.
