03-07-2010 09:05 PM
03-08-2010 02:08 AM
hi
Store the boolean value that goes to the DAQmx in a shift register? how to store it? could you please provide me some simple example?
thank you...
best regard
kelvin
03-08-2010 08:41 AM - edited 03-08-2010 08:43 AM
Create a set of shift registers in your loop. Wire the boolean wire into the right hand shift register.
If you aren't familiar with shift registers, then you really need to look at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Here, every time your input goes true, the XOR will toggle the boolean that is in the shift register going to the digital output. If your input is false, then the boolean continues through it its current state.
03-09-2010 03:41 AM
08-13-2013 05:15 AM
Hello sir,
I have siemens tc35 modem and i want to read message on labview using this modem, i check the modem using hyperterminal, it works well. i am using basic visa read and write vi but when i type AT in write buffer then it read the same as it supposed to be OK. could you please help me.I will be very appreciated.
thanks.
08-13-2013 08:23 AM
When you did it in hyperterminal, did you hit the enter key?
If so, did you send a termination character such as a carriage return or line feed at the end of the AT string when you tried to do this in LabVIEW?
08-13-2013 08:52 AM
hello sir,
how can we send line feed and carrier return? do we have to send both of them or just one?
please let me know.
thanks
08-13-2013 09:22 AM
Set your string constant or control to be \codes display. Enter \n, or \r, or \r\n, or \n\r. I don't know which one of those you need, but it shouldn't take long to figure it out.
03-20-2014 03:53 AM
does it work???
03-21-2014 04:18 AM - edited 03-21-2014 04:18 AM
What is your question? Does the GSM modem work, or the carriage return/line feed appending, or something else? If any of the aforementioned points is your concern then the answer is: YES.
