GPS and Xbee
Hey guys I am using labview for a school probject and as part of it I have to transfer data of the location from a myrio using a GPS sensor.
Does anyone know any good places on where to start as far as information about this?  It's kinda diffcult to find anyinformation on this, without using arduino, which I am not.  I am just using the myrio.
Thank you
Bobbie
Message 1 of 17
(4,762 Views)
GPS usaly is send over as NMEA string. ( http://en.wikipedia.org/wiki/NMEA_0183 )
there are examples for the serial protocol.
If I am not mistaken most Xbee modules also interface as serial protocol.
Learning LabVIEW since January 2013
Message 2 of 17
(4,736 Views)
Found this myRIO and GPS demo the other day.
http://www.youtube.com/watch?v=SebcpkbYBd4
I build web apps for LabVIEW
http://chrislarson.me
Message 3 of 17
(4,731 Views)
How does he get -1 in his property node.  It only lets me to go to zero.
Message 4 of 17
(4,689 Views)
Hi bobWalt,
It's really hard to see, but I'm pretty certain there's a coercion dot on there. The Text.ScrollPos property node is an unsigned integer, so a -1 will be coerced to 0.
Best Regards,
Matthew B.
Offering Manager
NI
Message 5 of 17
(4,660 Views)
@Matthew-B wrote:
Hi bobWalt,
Best Regards,
wiring the -1 to the scroll pos property, and letting it be coerced intentionally, is a common work-around to always scroll to last line.  This often contains the most recient information when you append to a string rather than prepend.
"Should be" isn't "Is" -Jay
Message 6 of 17
(4,654 Views)
Ok guys I ran the code as 0, and now i'm getting following error:
Message 7 of 17
(4,635 Views)
I looked up the error as shown above but i am not getting the following timeout error:
http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0
Message 8 of 17
(4,634 Views)
That usually means you have a connection problem:
  • Wrong COM Port
  • Wrong Serial cable (NULL modem / Straight patch)
  • Wrong port settings
  • External device turned off/not configured/
Looking at the vi: the first thing you do is read from the port.  Most devices don't just "spew data" out a serial port.  What is the device and have you read the user's manual?  User's manuals are like text books- you won't learn much about the subject without reading themSmiley Wink
Message 9 of 17
(4,609 Views)
for clairification what does the mean?
and the gps in question is a adafruit ultimate gps breakout see below
http://www.adafruit.com/products/746#Technical_Details
I intially did get one reading out of it.  And then when i returned to the code i kept getting the error above.
Bobbie!
Message 10 of 17
(4,593 Views)
