GPIB to RS-232 Transition
Sorry.. i forgot to attach my VI.
Here it is.
Message 11 of 20
(2,144 Views)
Sorry..Forgot to post the VI.. Here it is
Message 12 of 20
(2,143 Views)
Hi Pa1,
can you answer the questions from my last post?
Especially the question on TermChars?
Does your device wait for a special TermChar when receiving commands over RS232? What is mentioned in your manual on this topic? RTFM…
Using BytesAtPort is also wrong here! How many bytes do you expect in the receive buffer immediatly after sending a command? Either use the TermChar described in your manual or request the exact number of bytes in the expected message!
Message 13 of 20
(2,141 Views)
Here are the answers.
1) The coonections are perfect.
2) I have sent only the *IDN?\n command
3) What is TermChars?..Is it terminal characters. I have tried it with \n and without it..but the result is same
4) VI is attached?
Message 14 of 20
(2,134 Views)
Hi Pa,
No, you don't!
There is no NL char (\n, new line) in your command!
Message 15 of 20
(2,128 Views)
Hii..GerdW...
The result is the same even if the \n is added.
Message 16 of 20
(2,131 Views)
Hi Pa,
there is a difference between the NL char and your "\n" chars!
You wrote two chars: "\" followed by "n".
Your device expects a NL char, written in \-code-display as "\n" or in hex-code-display as 0A!
Message 17 of 20
(2,124 Views)
Thanks GerdW...
Are RS232 and GPIB command format the same?
Message 18 of 20
(2,116 Views)
Hi Pa,
As has been mentioned several times before: Read the manual of your device! RTFM…
(Most often the commands are the same. But as I already mentioned above the termchar may change.)
Message 19 of 20
(2,107 Views)
You are not configuring your serial port!
Try something like this:
=== Engineer Ambiguously ===
Message 20 of 20
(2,100 Views)
