GPIB PROBLEM
There is just no need for a dhcp server. You have a pc with a fixed ip and the instrument with a fixed ip on the the same subnet as the pc. Nothing fancy required at all.
Message 41 of 66
(344 Views)
Hi Mr.
thanks for reply.
I did change the Ip addresses but i cant connect either to my MAX or using ping method as in this link - http://www.tek.com/support/faqs/how-do-i-connect-my-oscilloscope-ethernet-connection-ni-visa
or do i have to download the latest NI.VISA (14.0)?
Message 42 of 66
(331 Views)
If you can't ping the device, then you have problems at the lowest level unrelated to VISA or LabVIEW.  How are you physically connecting the PC to the instrument?  If it is a direct cable, is it an ordinary ethernet cable or a cross-over ethernet cable?
Message 43 of 66
(324 Views)
Thanks for the reply Mr.
i actually connect it using networking cable. cable that is alwas used for internet.
Message 44 of 66
(319 Views)
That doesn't answer the question. If your nic does not auto-switch, you need a cross-over network cable.
Please provide the ip's for the instrument and the pc. Neither should have dhcp turned on.
Message 45 of 66
(308 Views)
I didn't see the post where both the computer and the Oscope had fixed IP addresses, especially when the Oscope error indicated it was set up to automatically obtain an IP address.
My take was that the computer was usually connected to the company's network and was getting it's IP address from the network and the Oscope is configured to its default, which is DHCP.  Now the computer was taken off the network and defaulted to a local IP address.  If that was the case, it might have been simpler for the user to simple get a router so that they can both be auto-config'd, instead of asking someone who is obviously a computer novice to configure his computer manually.
Bill
CLD
(Mid-Level minion.)
Message 46 of 66
(297 Views)
Dennis, I think you may have assumed the wrong thing.  I still see no post where he had manually configured his computer's IP address.
Bill
CLD
(Mid-Level minion.)
Message 47 of 66
(288 Views)
I didn't see it either, which is why I asked for it.
Message 48 of 66
(277 Views)
is this what you requested?
Message 49 of 66
(264 Views)
That appears to be your Wi-Fi connection to your internal network. You have another, dedicated port on your computer, don't you?
Message 50 of 66
(249 Views)
