Hi all,
Well I was the one who suggested that hehe ... teorically when you got 2 NICs the problem is that windows takes one as default and MAX (Measurement and Automation Explorer) only uses the default one to check for instruments/equipment. Normally that is solved changing the order of the NICs on Networks configuration and assigning the default to the one connected to your equipment.
This was a quite extrange issue, because it neither worked making that card to be the default one. I didn't know that windows XP distributes the network traffic to both cards when they are on the same subnet or that it used arbitrary one or another. This behaviour I think happens with Unix but I didn¡t know that for Windows.
Anyway, just take in consideration to have the NIC as default and in another network than the other NIC for any kind of situation using NI equipment and you will be sure that things will work ok,
Jaime Cabrera
NI Applications Engineering Spain
