G# StarUML installation LabVIEW 2020
I'm trying to install the G# StarUML plugin and I have a couple of questions:
  • Does this plugin works with LabVIEW 2020 Windows 10 ?
  • Is this plugin developped for StarUML or WhiteStarUML ? I always receive a message telling me that StarUML is not installed.However, I installed both StarUML and WhiteStarUML.
Thanks for your help.
Best Regards.
Christophe
(1,288 Views)
There is a G# board here. Please ask there. But I can tell you that there is an installer for either WhiteStarUML or StarUML 1 (Not StarUML 2), but there were problems packing the installer to vipm, so instead you should get the latest installer directly from AddQ. There is an installer at the G# webpage addq.se/gsharp, but I am not sure if the downloader is the latest one, so I suggest to post a question on the G# forum too.
Certified LabVIEW Architect
(1,218 Views)
It was originally made for StarUML, and later WhiteStarUML as StarUML died and WS picked up the flag.
It does not support the new StarUML2 since it uses a completely different file format and is java based (i think).
It can probably be done but there's been no time to look at it. 🙂
I see no reason why it shouldn't work with 2020, the installer only copies some files to both programs folders, so unless those have changed it should work.
I'm running it with WS 5.9.1
Qestit Systems
Certified-LabVIEW-Developer
(1,206 Views)
