Functions on Hp 4192a impedance analyser
Hi, I attempted to create a simple program using the drivers i found the analyser but i failed so swiped a program i found on here,
my aim is to be able to run log frequency sweeps and have the output |Z|/|Y| and angle in degrees, however the program i swiped calculates addmittance (R/G X/B) which is a different function of the analyser
one of the inputs is mode which i assumed to be function however this isn't the case does anyone know how to change the functions or is it the whole program which needs to be changed?
I've attached a copy of the program and the input file (which is just a list of frequencies)
any help will be much apprieciated
Ben
Message 1 of 1
(2,274 Views)
