Function palette is too small in the block diagram . how can i set large size this palette ?
The function palette is the little dialog window from where you choose functions to paste on the BD.
In can see a BD but no palette in your picture. What do you mean precisely?
Paolo
Message 2 of 8
(2,811 Views)
I want to set large height and width this Tone Measurements , Amplitude Measurements . 
Message 3 of 8
(2,800 Views)
I am guessing you want to zoom in or zoom out of a block diagram...?
Unfortunately therse is no way to zoom in or out on a block diagram.
BTW: People have been asking for this ability for well over a decade.
=== Engineer Ambiguously ===
Message 4 of 8
(2,767 Views)
I'm not sure what you really want to do.
Do you want to enlarge the Express-VIs 'Tone Measurement' and 'Amplitude Measurement'?
If so, you can right-click the Express-VIs and uncheck 'View As Icon'.
Message 5 of 8
(2,758 Views)
The only thing I can think of is to set the Display Resolution to a numerically lower resolution. That would "zoom in" the block diagram but would also make other objects not LabVIEW related also appear larger. Not sure if the OP wants that.
Message 6 of 8
(2,748 Views)
You could increase diagram readability dramatically by simply resetting the background color back to normal.
(Is your font really 20pt by default? That will distort a lot of things.)
Windows 10 also has accessibility tools for the vision impaired, such as the magnified tool. (Try settings...ease of access)
Message 7 of 8
(2,736 Views)
It looks like you are using Express VIs. Right click icon and deselect view as icon. That will make it a little bigger. See below.
Message 8 of 8
(2,699 Views)
