I use LabView 5.0; NT4 SP4; MS DevStudio VC5 I've written a C++ DLL, an declared exported functions as extern "C" __declspec( dllexport ) Quick View finds the exported functions, my test application finds the functions, even the Get DLL Exports.vi (provided by NI) finds the functions. But if I make my own Call Library Node it insists that the functions do not exist. Using C instead of C++ is no good choice since I use some Afx stuff that probably wont work under C. I think the solution is so simple that I do not see it (no, not case sensitivity 😉 ) Any help would be grate Thanks Stephan
Sent via Deja.com http://www.deja.com/ Before you buy.
