05-23-2011 04:16 PM
You can certainly perform a frequency measurement on the analog signal you get from the 6009. I have no idea what you tried to do but just wire the signal out to something like Extract Single Tone.
05-23-2011 04:27 PM
Hello wolfp
If you access the LabVIEW example finder, can you find this VI: Acq&Graph Voltage-Int Clk.vi
The folder tree for this VI in example finder is Hardware Input and Output --> DAQmx --> Analog Measurements --> Voltage --> Acq&Graph Voltage-Int Clk.vi
I would really appreciate if you could describe your project in more detail so I can better assist you with your issue.
Thanks again!
