Frequency measurement using myRIO clock
Hi everyone,
I am looking to find the frequency of an analog signal using a function generator connected to the MSP input of myRIO.
The idea is to use the FPGA target on the NI myRIO (40 MHz clock rate) as a reference clock of 10MHz, for example, to define the sample clock.
I added the myRIO while loop to the FPGA signal generator example: the voltage from the function generator is correctly acquired but building the waveform I can't measure the frequency, neither with the tone measurements VI or the FFT (figure 25). What is wrong?
How can I be sure that the two signals are synchronized (as well described here)? I guess with a timed loop and a master/slave architecture but I'm not sure how to implement it.
Thanks a lot
John
(3,786 Views)
Hi John,
What kind of error are you getting when you try to calculate the frequency of the input when you use the tone measurements VI or the FFT?
I would recommend checking out the following White Paper for instructions on how to synchronize your signals https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fz1lSAA&l=en-US Let me know if this doesn’t work.
Cheers,
Scott B.
AE NI
(3,732 Views)
