Frequency domain filter to time domain filter
If you Google this phrase -> locale variables labview. You will find a lot of useful information on the first page. Then working with locals in Labview, they make copies of data buffers. When you read from a local variable, you create a new buffer for the data from its associated control. If you use local variables to transfer large amounts of data from one place on the block diagram to another, you generally use more memory and, consequently, have slower execution speed than if you transfer data using a wire. So the only advise I can give you, is use them with care. Always have I mind their cons. I think it is wrong, not to use them if they make sense in your programs. But be aware of race conditions.
Also if you have 2 loops running in parallel, both working with same variable. You should consider the Producer/Consumer design pattern.
More about it here http://zone.ni.com/devzone/cda/tut/p/id/3023
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 14
(1,234 Views)
Here is the exact vi on which I'm working.
I try to generate a continuous audio signal and to measure it with labview by plugging the sound card output directly to its input.
The vi has two loops : one for generating audio signal and the other to measure it.
It works fine but I don't understand why as there isn't any control structure between both loops.
Should I use a semaphore or any other control for parallel running loops ?
Message Edité par Alexandre.DaCosta le 04-03-2009 08:50 AM
Message 12 of 14
(1,222 Views)
Think about your soundcard as 1 AD unit and 1 DA unit. This units are separated so they do not have to know about each other. They actually works best that way. So I would not change any thing in your setup. Then I am working in may lab with soundcard input and Labview, I sometimes listen to music played with winamp. No problems at all.  Just remember that it will always be some latency between soundcard output and input. In your case it will be .5 second since you plan to update your sound meter every .5 seconds. But this doesn't matter at all.
Message 13 of 14
(1,212 Views)
JK1,
Would you be so kind as to save the file "Test A-weighting edited.vi" as an LV 8.5.1 version?
I can't view the file
thanks
Bob
Message 14 of 14
(1,013 Views)
