05-12-2016 08:55 AM
Hi Hayk,
but it isn't good for my project.
Well, your display should not need more than 15Hz update rate.
What's so wrong and "bad" for your project you can afford to send data from FPGA to RT, process the data easily, and send them back to FPGA?
05-12-2016 01:37 PM
@GerdW wrote:What's so wrong and "bad" for your project you can afford to send data from FPGA to RT, process the data easily, and send them back to FPGA?
I'm not even seeing a reason to send it back to the FPGA. Just have the FPGA process the raw data and pass it to the RT using the front panel access. The RT can do the conversion purely for the display (a simple Format String will do the job).
05-12-2016 01:43 PM - edited 05-12-2016 01:44 PM
05-12-2016 02:16 PM
@GerdW wrote:I think Hayk talks about a hardware display taking this U8 array as input…
Now that would make more sense, and a key bit of information. Then the question becomes "how is the data written to the display?" Serial port? Digital Outputs?
05-12-2016 02:27 PM
Interesting problem! A few more ideas:
Jim
