Formula Node output display bug
I was able to reproduce it with some caveats - only some variable names would shift. For example, lowercase i and uppercase X would never shift for me, but some other variable names would.
CAR 469268 has been filed regarding this issue.
Thank you for your continued feedback X. !
Nathan Murphy
C Series I/O Product Manager
Message 11 of 13
(1,004 Views)
OK, not sure again what you were or were not able to reproduce, but at least someone knows that the Formula Node outputs (what about inputs?) have a live of their own.
I'd suggest to take a look at the MathScript Node, in case they share some code.
Message 12 of 13
(994 Views)
I was able to reproduce the variable names shifting by 1px every time the VI is opened, saved, and closed. However, with some variable names I did not notice the behvaior. This was tested with inputs and outputs, and the bug was present with both. However, this only happened when inputs and outputs were located on the top and bottom borders.
Nathan Murphy
Message 13 of 13
(976 Views)
