Formula Node Error
I am entering this formula :
z = -10*log((10**((x)/10))-(10**(-(y)/10))); in the formula node.  An error is displayed. Error on line 1 is marked by a '#' character: "... = -10*log((10**((x)#/10))-(10**(-(y)/10"    Formula node: array indexing expected. Did not get it. Please provide me with a solution
(278 Views)
Hi Chhavi,
Did not get it.
So you wire an array to your formula node - and don't get the error ""array indexing expected"?
Why use a formula node at all?
Because of famous polymorphism you can easily replace the controls/indicators by arrays…
CLAD expired, using 2009SP1 + LV2011SP1 + LV2017 (+LV2019 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
(264 Views)
A for loop around the expression node would work too.
Indeed, no reason for the FN...
(215 Views)
You can process arrays in the formula node, but it's quite a hassle
(204 Views)
I abhor the formula node for the simple reason that you have no chance for syntax error using native math primitives instead.  (My typing is, well... bad.)  Smiley Very Happy
Bill
CLD
(Mid-Level minion.)
(163 Views)
Highlighted
I do like expression nodes for simple scaling, like going from mm to m and vice versa.
A typical bug with the formula node and expression node is related to the fact that we use commas as separators over here. And when you use a number with a comma, you can get a valid expression, but not a valid result:
y=x*12,34;
This results in y=12 for x=1, not y=12,34!
(143 Views)
Moreover, you can't inline a subvi, which has an expression node or formula node within
that's the main reason we use those structures only for prototyping
here's my favorite:
http://zone.ni.com/reference/en-XX/help/371361R-01/lvinstio/degrees_to_radians/
(138 Views)
