02-21-2019 06:25 PM
See attached VI - I have figured out how to store each "block" of sensor information using an array & shift registers, but only in a 1D array.
I'm stuck on how to format this for easy reading in Excel! Ideally I just want to import a csv file and have a column for each sensor reading, and a timestamp marking each row of data.
No idea how to take my column of sensor information and turn it into a 2D array, or if my data logging method is hokey and should be replaced with something more efficient
02-22-2019 11:34 AM
Yoooo I figured it out my dudes
I didn't realize you could drag down the initialize array icon to add another dimension. I just dragged it down one and set it to 8 columns for my 8 datapoints, and then the build array function worked!
