You cannot use a different format for each column of a 2D array. In an array, all the elements are identical, except their value.
If you want to have a different display, for instance a different number of sign ificant digits, you should use a table instead.
See the attached vi that shows how to convert a 2D array to a 2D string table, with a different digit number in each column.
Chilly Charly (aka CC)
E-List Master - Kudos glutton - Press the yellow button on the left...
