I am interested in storing various forms of data in a single file, and then being able to access this file from other environments (VB). As an example, I might want to store a 2D array of U32, a 1D array of strings, and a single string within the same file.
It appears one way to do this is to convert each data object to a variant, then write the variant to a byte-stream file. LabView is able to read this back without problem, but I would like to be sure that this data would be readable from other programming environments (e.g. Visual Basic). To do this, I need to know how LabView stores variant data. This topic does not appear in Application Note 154, "LabView Data Storage".
Andy
