For Loop exits prematurely - Arrays and Shift Registers
I have attached some preliminary code (work in progress) for the RC4 encryption algorithm. For some reason the middle for loop exits prematurely. In other words it exits after 2 iterations instead of the 256 iterations that N is set to.
I thought this was not possible and therefore I am presuming I have made some not so obvious error in attempting to use a shift register with an array.
Please have a look. Thanks.
(2,953 Views)
You misunderstand how a for loop operates. You can either wire a number to the N terminal or you can wire an array into it with auto-indexing turned on. With an array input, the for loop will iterate equal to the size of the array. When you wire both (a practice I do not recomend), the for loop will iterate to whichever is smaller - the array size or the N terminal. Both of your for loops on the left side is creating arrays with only two elements. I suspect that what you need in both of them is a shift register instead of exiting the for loop with auto-indexing turned off.
(2,945 Views)
It seems the problem is located in the left two for loops. The array output from the for loops contains only two elemnts.
Hope this help.
HMP
(2,941 Views)
Thanks for the explanation.
(2,934 Views)
