Flow control for stopping an earlier loop?
Hello All,
  Having trouble the flow control for a DAQmx configuration subVI.  I need to configure an anolog-out instrument, then continually loop the write function to maintain a constant output.  After the loop has started, I need to read a message on another instrument (happens to be RS485 card).  Then, after I have read the message, I need to stop the analog-out loop.  This sounds like it should be pretty simple, but I can't seem to get the order of operations correct.  Tried local variable, flat sequence structures, and nested while loops.
To summarize:
Process A needs to start and run continually
Process B must wait for Process A to start, before it can start
After Process B has finished, need to go back and stop the loop for Process A
I've worked with situations similar to this before, using local variables to stop parallel loops, but it was never dependant on one process needing to wait for another one to start.  I do realize that I could simply implement a delay on the second process, but that would really just be guessing at the completion time (not preferred).  Please advise.  Thanks.
GSinMN
(2,712 Views)
You initialize before both loops and then run the two loops (write to AO and read RS485) in parallel.  I would use a Notifier to tell the loop(s) when to quit.
(2,697 Views)
