09-03-2020 01:31 PM
Hello, I am using FlexRIO 7932 to retrieve data through DMA FIFO from FPGA to Host. In host vi, when "Number of Elements" is set to 0 inFIFO.read Invoke Method, "Elements Remaining" return value or this value plus or minus one can be divided by 32. Since I only need the last portion of the last FIFO data after several FIFO reading, this will cause data loss. I need help to have a better understanding on how FIFO reading works in FlexRIO. Thanks!
09-03-2020 01:37 PM
Is there a way to control the amount data being sent from the FPGA? Maybe using the Streaming VIs: http://zone.ni.com/reference/en-XX/help/372614J-01/target5devicehelp/idl_streaming_vis/
09-03-2020 01:46 PM
Thanks for your reply. To FIFO.Read (Invoke Method), I read the NI document about Elements Remaining: "Elements Remaining returns the number of elements remaining that are available for reading. The number of elements that this method returns is less than or equal to the actual number of elements remaining in the FIFO." This means it may not be the actual data size, then how to check the available FIFO size?
09-03-2020 04:46 PM
The only situations I can think of that would result in elements remaining returning less than the actual number of elements remaining would be:
