If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Flatten floating point on FPGA for multichannel DMA
Flatten to boolean array (free on FPGA) and then re-cast to U64 (Again essentially free if the number of bits actually match).  On the receiving end, perform the opposite and bob's your uncle.
We do this all the time.
Shane.
Message 11 of 17
(5,203 Views)
Intaris that definitely is a step in the right direction, and will take care of most of our data types, but the "number to boolean array" node apparently doesn't support floating point.
Steve
Message 12 of 17
(5,188 Views)
Really?  That seems like an oversight on the FPGA module side.....
Message 13 of 17
(5,185 Views)
At this point we plan on converting to fixed point before converting to bit array for packing into the DMA.
Message 14 of 17
(5,156 Views)
I'm coming into this a little late, but just in case someone find this useful.
You can implement your own conversion to/from Single using an IP Integration Node. I have attached the code to do this and it should work on all platforms (although you may be asked to regenerate some files). The actual VHD behind the scenes is very simple since the flattened types have the same bitwidth (I chose to use U32 as the flattened representation).
library IEEE;
use IEEE.std_logic_1164.all;
entity ReinterpretType is
    generic
        kWidth : positive := 32
    port
        oldValue : in  std_logic_vector(kWidth - 1 downto 0);
        newValue : out  std_logic_vector(kWidth - 1 downto 0)
end entity ReinterpretType;
architecture rtl of ReinterpretType is
begin
    newValue <= oldValue;
end architecture rtl;
The IPIN usage looks like the following (fill in your code between the flattening and unflattening).
I've also attached a sample project for you to try out.
Message 15 of 17
(5,127 Views)
Intaris,
I'm finally implementing your suggestion.  I assume you aresuggesting the lower path for encode/decode because it's cheaper on FPGA?
Thanks!
Steve
Message 16 of 17
(5,087 Views)
Please kudo this idea to add support for bit reinterpretation (type cast) in FPGA.
Message 17 of 17
(1,689 Views)
