05-05-2015 07:54 PM
Hi
In the attached LabVIEW FPGA code I get the following error when I try to complie the code:
LabVIEW can not determine the size of the array output because arrays of
different sizes are wired to the Feedback Node.
Could you please let me know how can I resolve this issue
and make the input "fixed size "to the Feedback Node?
05-05-2015 10:42 PM
How many elements do you have defined in the boolean array going into the initializer of the feedback node?
05-05-2015 11:04 PM
That one is also 24. So I get data from 24 IOs , initializer array has 24 elements and the array subset VI also passes 24 elements and I don't know why I get this error
05-05-2015 11:15 PM
What if you don't use the boolean array to number which is outputting a U32. Maybe 32 bit vs. 24 booleans is confusing it.
05-06-2015 12:07 AM
I deleted the Boolean array to number and replaced it with a Boolean array indicator and changed the type to 24bit fixed and I see a red dot on the input terminal.
And I get the same error when I complie.
The input to the Feedback Node is ID array of Boolean (not fixed size ) and the output from Feedback Node is also not fixed size .
05-06-2015 02:07 AM
On the FPGA all arrays must be fixed size. Make sure the constant array wired to the initializer is set to fixed size 24 elements.
05-06-2015 02:14 AM - edited 05-06-2015 02:16 AM
05-07-2015 11:18 AM
If you hover over the wires and look at the context help do all of the arrays show a fixed-size of 24 elements?
The only way I could reproduce your issue was by having the initializer constant value set to a size other than 24 elements. My example wasn't exactly the same as yours, but from the compilers perspective they should be identical as far as the array sizes are concerned.
