01-17-2006 08:01 AM
01-17-2006 08:12 AM
Hi
This may be a quiet difficult approach if you're not so used to LV yet:
Last year a made the program for a test rig, where 7 units are tested in parallel. So I used opengoop to create an object for each item, which was passed from test to test, as each item was moved on to the next station after the test. In the main application I have a statemachine, which runs 7 subvis (one for each test) in parallel in the test-case. So no huge block diagram and furthermore some tests were similar, so I made the subvi reentrant to really run them in parallel.
Thomas
01-17-2006 10:22 AM
01-17-2006 10:45 AM
01-17-2006 01:04 PM
01-18-2006 12:13 AM
01-18-2006 07:28 AM
01-18-2006 07:41 AM
