05-30-2008 06:48 PM
Firstly hello to all. I’m looking to create a vi that will take a single logged output from a thermocouple and monitor the temperature and produce a Boolean when the temperature has stabilised for a pre determined time say 1minuet. I have managed to find a couple of examples on the forum but one will only run on V8.2 and I have V8, the other is for more than one channel witch is fine I can always reduce this, but it was the timing feature I was having difficulty with. I looking to monitor the temperature of a motor until it has stabilised prior to testing and then to use this temperature as a reference. Pleas forgive my ignorance if this is a very simple thing but I’ am learning and really enjoying it. Thank you in advance for your answers.
05-31-2008 01:01 AM
Firstly, keep your question title as simple as possible.
Secondly, please dont repeat the same question as in the title again in the message.
06-02-2008 03:18 AM
06-02-2008 03:30 AM
06-02-2008 04:18 AM
What I’ am trying to achieve is a vi I can use in a motor testing setup, a part of this would be to warm the motor up until the exhaust air temperature has stabilised, this takes approximately 10 minuets. I was thinking of just letting the motor run for this time and leave it at this, but some motors warm up quicker that others and. I am basically looking for a vi with an adjustable temperature window of say ±5 C° in 1° increments, timing wise 1minuet to 10min the adjustment is so I a can use this for another application. I tried to adjust the code I found at the link below but had a little difficulty with the timing. Thank you so much for your help it’s much appreciated.
06-02-2008 04:22 AM
Hi new2this,
here is the vi for 80.
Mike
06-02-2008 04:34 AM
06-02-2008 04:51 AM
Hi new2this,
try something like this.
Hope it helps.
Mike
06-02-2008 05:18 AM
06-03-2008 03:20 AM
Hi Mike, thank you so much for your help I thought the forum would be a bit useless but there are so many helpful people here of witch you are one. I hope that some day I will be able to repay the favour.
Craig
