Firewire IEEE 1394 camera not visible in NI MAX
The Windows command "ipconfig" only describes IP configurations (hence the name), so it will show Ethernet and WiFi, but will not show USB and (probably not) FireWire connections. I'm not even sure if it will show BlueTooth (I doubt it).
I am using a USB Camera that has a Driver provided by the Vendor.  When this Driver installed, MAX can "see" the camera, but cannot open it (it is described, correctly, as "FLIR USB3 Vision Camera", and shows "USB-0" as the port into which it is plugged).  If I try to open it, I get Error 0xBFFF801D, The selected device is not currently associated with the IMAQdx Driver.  Right-click the device to select which driver is in use".  After I select the NI-IMAQdx USB3 Vision Device and switch to the correct driver, the Camera appears in MAX and can be opened.  I suspect you have a similar problem with the FireWire driver -- you somehow need to "attach" the NI -IMAQdx 1394 Vision Device (I'm guessing at the name) driver.
P.S. -- a recent White Paper discussing 1394 Cameras is here.  This is consistent with what I said above, but I thought to look after I posted (hence the P.S.).
Message 11 of 11
(947 Views)
