Finding No of Repetitions
Consider an example, this pulse waveform contains some random repetitions of 0’s and 1's
Here the occurrences of value 1 is 21 times. So, how I can count this programmatically as No of 1's as 21
If I use Search function of array, just it display the corresponding y axis value of the First occurrences of 1.
How can I perform this operation???
Regards
Gokul
(2,691 Views)
Hi gokul,
just count the them:
If you want to count just rising edges: use a rising edge filter before (PtByPt-BooleanCrossing!)...
(2,686 Views)
Thanks for your kind reply GerdW.
when I follow your code. Just it gives no of repetitions of 1 on the basis of X - axis value. If my pulse is continuously giving 1 from ( 0 - 389 in X axis )
It shows 389... But see above output picture there is no occurrence of 0 (from 0 to 389 in X axis ) right. so, my goal is to take that as one occurrence of value 1.. If my pulse again goes to higher state then count it as 2 till it falls to low state.
Can you getting my point.??
Looking for your kind reply.!!
Regards
Gokul
(2,677 Views)
Accepted by topic author gokul2013
Hi gokul,
did you read my comment on using a rising-edge filter in message #2?
Did you even try to use that? Did you try to configure the mentioned Vi to detect falling edges?
(2,670 Views)
Thank you GerdW..
Now I got the point. Thanks a lot.
(2,667 Views)
