02-16-2012 06:37 PM
This one sounds like one I have already read about, but I doubt this qualifies as a "feature". I think it is an outright bug.
Anyway here it goes:
- drop two controls on the FP.
- group them.
- drop a Tab control, drag the grouped controls in it.
- switch to the BD.
- right-click one of the controls (not the Tab control, the other two) and try to "Find Control".
- for a brief second, the control will be highlighted, but eventually, the Tab will be selected.
That's OK when the Tab is not cluttered with controls and when you are careful watching where the highlighted object is located, but I do not think that this is an intended behavior.
Tested in LV 2011.
02-20-2012 04:03 PM
X.
I've successfully replicated your setup and I see the same behavior you describe. However, this behavior is expected since LabVIEW will show the largest container of the item you are trying to find. I see that you are already familiar with our Idea Exchange, and you may want to post this topic there if you haven't already.
KyleP
02-20-2012 04:48 PM
KyleP, thanks for trying to reproduce and confirming the symptoms. I fail to see how selecting the tab will help me in any way... even if it supposedly the "expected" (by whom?) behavior.
I have reported this as a "feature" in a related thread I read in the meantime.
02-21-2012 03:46 PM
I understand that this is not the ideal behavior for your application, however LabVIEW is intentionally designed to do this. Thank you for following up with another post. I hope that it will generate some useful discussion.
KyleP
02-21-2012 04:15 PM
02-22-2012 02:49 PM
Zing 😉
I'm with you on this suggestion! At the time, I was pretty sure we'd found a bug so I grabbed a LabVIEW Expert to get his opinion. He was able to tell me that the code is not necessarily working incorrectly, but your situation might not have been taken into consideration during design. I'd say create a new thread on Idea Exchange to differentiate it from the other issue and get some Kudos on your post.
