05-04-2020 08:04 AM
We have a lot of tests in which we must search if the overwrite the preUUT callback.
I want to use teststand to load a test and search if that test overwrites the preUUT callback.
Is this possible?
Solved! Go to Solution.
05-13-2020 10:46 AM
You can use the method: RunState.Engine.GetSequenceFile("NAME OF SEQUENCE").SequenceNameExists("PreUUT")
I tested it by using the expression: Locals.Exists = RunState.Engine.GetSequenceFile("NAME OF SEQUENCE").SequenceNameExists("PreUUT")
to set a variable called Exists to true or false depending on whether the PreUUT callback had been changed or not.
05-14-2020 12:38 AM
Hi AlasdairMee,
Thank you for your reply.
I had some problems finding which reference to use, I had some exaples which use this context but below you can see that I use the reference 'Teststand UI...'.
Find myself a bit of a noob but it's solved.
