Find a capital letter in a string.
Hello, I have 10 strings and I need to search every sting for a capital letter. If there is a capital letter in a string I need to put the string in an array of strings. I don't know how to separate a string with a capital letter in it. If there is no capital letter than the string is skipped.  I tried using the Match Pattern function and it didn't help. Thanks in advance.
Message 1 of 9
(4,602 Views)
Okay... but what did you use for the pattern?
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(4,597 Views)
Meavy this could help you if I understood well the problem.
Message 3 of 9
(4,582 Views)
I used [A-Z]+. I'm fairly new to LabView and i saw a guy using that line on YouTube.
Message 4 of 9
(4,564 Views)
What did you do with the output of the "match pattern" search?  [A-Z]+ should work...
Message 5 of 9
(4,549 Views)
Yeah that's what I needed. Thank you very much for the reply and help. 🙂 Cheers.
Message 6 of 9
(4,541 Views)
I think your teacher will laugh at that solution.  😉
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(4,511 Views)
Or... You could convert the string to an array of U8s and look for any value greater than 64 and less than 91, decimal.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 9
(4,487 Views)
There is a function in the Comparison palette called Lexical Class.
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/lexical_class/
Sorry, couldn't find a youtube video showing how to use it Smiley Tongue
Not the simplest, but as a beginner it teaches for loop, while loop and conditional outputs.
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
Message 9 of 9
(4,431 Views)
