08-03-2012 03:09 PM - edited 08-03-2012 03:11 PM
@crossrulz wrote:
That is a feedback node. It holds a value and returns it the next iteration. It works the same as a shift register. So what Florian did is if you have an invalid number, return the previous number.
Of course this doesn't help because if you have 2 invalid numbers in a row, then the first invalid number is what gets pulled out of the feedback node.
Radio buttons are the correct answer here. And if you want them to look like what you have now, then customize them!
08-06-2012 08:19 AM
Here's a cutomized Radio Button for you to use. You can always right click and choose Advanced->Customize and put whatever boolean in there you want.
08-07-2012 03:29 AM
I'll use the radio buttons you provided. Thank you all very much and kudos!
Johan
