09-19-2024 12:46 PM
Hi!
I would like to have more information regarding the filter designed by the Rational Resampler Express VI.
We pretend to use this VI to downsample signals acquired with different sampling rates to the same output frequency, then write them to a single acquisiton file for post-analysis. By knowing the characteristics of these filters, we would be able to compensante their group delays.(which will be different for each case) and guarantee proper synchronization in time.
Best Regards,
Gabriel Brunheira
gabriel.brunheira@lnls.br
LNLS/CNPEM
Solved! Go to Solution.
09-19-2024 01:09 PM - edited 09-19-2024 01:15 PM
Well, let's look at that picture of the Express VI configuration page just a bit more closely.
On the lower right corner of that page are THREE Buttons. Did you see the rightmost button? It is Labled "Help". What happens when you actually PRESS THAT BUTTON!?
Hint: the explanation provided by the Help would be better than my own post could be.
09-19-2024 02:39 PM
Hi Jay,
We indeed looked up in the help page and as you can see below, the required information is not present:
We also searched for information in NI website and foruns, and nothing.
Best Regards,
Gabriel
09-19-2024 02:50 PM - edited 09-19-2024 02:56 PM
@gabriel.brunheira wrote:
Hi Jay,
Best Regards,
Gabriel
Great! Then you found out that the Express VI is not a filter at all. It simply is a resample of the data input when L =1 and a linear interpolation where L>1.
09-20-2024 05:16 AM - edited 09-20-2024 05:17 AM
Hi Jay,
With all the respect, I have the feeling you don't know what you're talking about, neither read the Help page yourself:
In any process of downsampling, you should limit the signal bandwidth (using a digital filter) before resampling to avoid aliasing: Downsampling (signal processing) - Wikipedia
I'm just asking for more information regarding this filter, which frequency response clearly appears in the Express VI shown above.
Best Regards,
Gabriel
03-12-2025 06:27 AM
Hi! In case anyone is interested, here's the response we got from a NI Engineer in a requested support regarding this question:
