Filter rows from an array, based on criteria in two of the columns
Highlighted
Is there an easy way to filter a 2d array, based on the values of two of the columns? For example in my VI attached the output array has the following format:
10:57:07.776
(960 Views)
Highlighted
Accepted by topic author chuck72352
Quick answer:
Convert your 2d array to an array of cluster where the order of the cluster defines how tie-breakers are handled (first fields are equa so serach on second item in cluster)
Run that thru a Sort 1d array and convert back to a 2d array.
Faster approach:
Only bundle up the serach fiels along with an index. Do the search then use the index to re-order the original array.
Ben
(951 Views)
Highlighted
I used the function "Build Cluster Array" and "Sort 1 D Array" as you suggested, then I dumped that to a file so that I can do the processing with a C routine. My plan is to write the filter routine in C then access it with Labview.
(940 Views)
