From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Filter Settling Time?
I am measuring vibration with a 9234 module.  The module is currently set to 2560Hz and I am reading 2028 samples with each iteration of my read loop.
I am using hte SVL Integration VI to convert from acceleration to velocity.  I have the included high pass filter set to 5 Hz.  I assume that this software filter has a settling time?
Assuing the answer to the above is yes:
Does the filter settle with each iteration of the loop or does settling happen only one time?  (Ther is no feedback to the integration vi from one run to the next.)
Is there a way to know how long the settling time is?
I assume that I could read extra data and then eliminate the initial data prior to any analysis to eliminate any data prior to settling?
(2,831 Views)
Take a look at these links as they may answer some underlying questions.
http://digital.ni.com/public.nsf/allkb/593CC07F76B1405A862570DE005F6836
http://digital.ni.com/public.nsf/allkb/F989B25FF6CA55C386256CD20056E27D
There is also a property node within LabVIEW in the DAQmx palette that can display or get the value that you are looking for. The property is AI.FilterDelay
Rob W.
(2,782 Views)
