06-19-2015 12:14 AM
I have a simple VI which takes certain measurement(temperature in this case) at every particular time period, and then saves it to a text file. As per convention, I used the procedure of open/create file,write, close. All this was inside a while loop. The VI runs, and stops as per whenver I want it to by pressing the switch. However, when I open the file it turns out to be blank.
Im attaching a screenshot of the VI.
Thanks, in advance.
Solved! Go to Solution.
06-19-2015 12:41 AM
06-19-2015 12:55 AM
I tried with the errors, it still showed the same thing. And I have attached a GPIB write outside the loop as shown.
06-19-2015 01:04 AM
06-19-2015 01:22 AM
Ok, I did as you said. I added a indicator at the output. Replaced my sub-vi's by the standard GPIB functions. It executes fine at the start, but at the second run of the loop, i get an error. I've enclosed a screen-shot.
Thanks for the help so far.
06-19-2015 01:28 AM
Attached is a better picture of the block diagram.
06-19-2015 01:28 AM
06-19-2015 01:35 AM
Cause pictures seem to tell more than words.
06-19-2015 01:38 AM
06-19-2015 01:48 AM
Dear Dennis,
any idea as to what the error I now get means ?
