Fatal Internal Error: "linker.cpp" when running an exe
Subject: Fatal Internal Error: "linker.cpp" when running an exe
I'm recieving the following error when running an executable:
    Fatal Internal Error: "linker.cpp", line 1926
    LabVIEW version 7.0
You will lose any unsaved work. For more assistance in resolving this problem, please relaunch LabVIEW, or contact National Instruments.
I've read about errors regarding linker.cpp and can't quite figure it out.  My main program is a front panel which lets the user select which action he would like to execute, when he selects an action the program calls the appropriate subVI.  When the user is done with the current action he can clear out that subVI and go back to the main front screen, in which again he can select another action.  The error occurs when an action is selected the second time.  It seems to me that LabVIEW has a problem calling the subVI a second time.  It calls it the first time ok but after it's cleared out the second call to it always bring up that error.
Thank you for any help,
~Matt
LV 7.0
Windows XP
LV 8.2.1
WinXP
(3,107 Views)
does this link help
http://digital.ni.com/public.nsf/allkb/3D4D80041B26EF8986256F710074F5AB
regards
Ray Farmer
Ray Farmer
(3,090 Views)
I don't think that article helps.  My main VI and all my subVIs have unique names, as they are all in the same directory.  Also, my program will load and execute, that error only arises when a subVI gets executed more than once in the main execution.
Thank you,
~Matt
LV 8.2.1
WinXP
(3,086 Views)
Hello!
Does your application contain Express VIs? If so is the case check out the following posts by my colleagues Philip Courtois and Jochen Klier:
http://forums.ni.com/ni/board/message?board.id=170&message.id=131760&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=138244&requireLogin=False
It is a bug with LabVIEW 7.0 and was fixed in 7.1.
Message Edited by Jimmie A. on 07-10-2006 08:02 AM
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,085 Views)
Hello!
Jimmie Adolph
(3,085 Views)
Hello...
Defining your Sub-VIs as "Reentrant" might solve this issue. You could do this by clicking on "File" menu, "VI Properties" and then selecting "Execution" as the category. Under the execution property page check the option for "Reentrant Execution".
Chetan K.
Application Engineer
NI
(3,066 Views)
Success!
Between taking out all the ExpressVIs I had and making the subVIs all reentrant the error as yet to show it self again.
Thank you all very much for your help.
~Matt
LV 8.2.1
WinXP
(3,059 Views)
