Found a solution to the problem...
As the error indicates there is a problem with the user's profile folder 'My Documents'. Domain administrator did not have 'My Documents' in his profile. After creating such a folder there manually, RTE installation worked successfully.
So now the question rises: why RTE installation requires such a folder to exist? Nothing is installed there!
My opinion is that RTE installation needs to be much more reliable than it is currently. Professional developers who make commercial products using LabVIEW will have a lot of pain with the current solution.
1) Customization options for RTE are poor. I think that most of the companies that deploy their LV-made application want no extra stuff installed. If the developer knows that e.g. TDMS or NI-REPORTS are not used in his application, there should be an option to NOT install these with RTE!
2) There should be more documentation (by NI) on RTE installation and its error handling should be improved.
I hope more discussion on RTE.
Wirer
Message Edited by Wirer on 04-04-2007 08:48 AM
