03-23-2009 02:55 AM
Hi Ppl,
I just wanted to know, what could be the fastest way to pick the maximum element from a 2D array .
That is i want to implement C(i,j)=max(A(i,j),B(i,j))
I do not want to index each element and select the maximum of two, as it would take more time to execute.
I tried the below method to implement this. The problem with this is, when a NaN is passed as input, NaN is returned
as output, irrespective of the other input. I don not want this to happen.
Can any one suggest a better method to implement this...?
Solved! Go to Solution.
03-23-2009 03:07 AM
03-23-2009 03:10 AM
03-23-2009 03:12 AM
However the max/min of (NaN, NaN) ist still NaN !
So you still have to look for that case 😉
03-24-2009 01:13 AM
Hi Ppl,
What makes such a difference in the execution speed, when we use a function from LabVIEW and use our own VI.
Is it that these functions are precompiled makes such a difference, or that they are done efficiently ?
I guess both should be the reason that they their execution times are less.
