Fastest way to compute C(i,j)=max(A(i,j),B(i,j))
Hi Ppl,
I just wanted to know, what could be the fastest way to pick the maximum element from a 2D array .
That is i want to implement C(i,j)=max(A(i,j),B(i,j))
I do not want to index each element and select the maximum of two, as it would take more time to execute.
I tried the below method to implement this. The problem with this is, when a NaN is passed as input, NaN is returned
as output, irrespective of the other input. I don not want this to happen.
Can any one suggest a better method to implement this...?
(2,775 Views)
Accepted by topic author lordsathish
Use the Max and Min primitive from the comparison palette. It accepts arrays and will even ignore NaN.
___________________
Try to take over the world!
(2,767 Views)
Use the Max & Min function node. Not really sure of what the O(n) of that function is.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,763 Views)
However the max/min of (NaN, NaN) ist still NaN !
So you still have to look for that case 😉
Greetings from Germany
Henrik
LV since v3.1
(2,758 Views)
Hi Ppl,
What makes such a difference in the execution speed, when we use a function from LabVIEW and use our own VI.
Is it that these functions are precompiled makes such a difference, or that they are done efficiently ?
I guess both should be the reason that they their execution times are less.
(2,692 Views)
