07-27-2011 03:56 PM
The first thing you really have to know is whether it is really Ethernet/IP (IP = Industrial Protocol) or it's an Ethernet connection that uses TCP/IP (IP = Internet Protocol). As you can see Ethernet/IP uses defined ports that are NOT 546 and 547.
The wireshark dump is pretty brief. I'm not at all convinced that you are showing the relevant section.
07-28-2011 06:25 AM
Okay, I have restarted wireshark and then connected from the software to the product. Included is the wireshark information - I hope this helps.
Thanks for the advice.
07-28-2011 05:46 PM
That lists the documented ports for Ethernet/IP (Industrial Protocol)
08-01-2011 09:02 AM
You said "That lists the documented ports for Ethernet/IP (Industrial Protocol)"
I assume this is because the EtherNet/IP-2 port shown under Transmission Control Protocol is 44818, so it is Ethernet/IP (Industrial Protocol).
Now the question is, where do I go from here? After the connection is established, it looks like the communication is UDP on ports 64079 and 2222.
08-01-2011 09:25 AM
08-01-2011 09:40 AM
I have used the NI EIP module on a big project recently, however never directly interfaced it with a Fanuc robot (I haven't built a robot-machine since the EIP module was released).
I have only used the Modbus TCP (DSC) package, and it worked pretty nicely. I spent some time manually locating bits in the Modbus pool, but I believe a call to Fanuc CRC (tech support) would aid in this tremendously (I was missing the Modbus protocol roadmap).
I used 16 in/16 out. Mapped the UOP's to modbus-outputs on the Fanuc, and had a 5-bit GI/GO to send RSR commands and other integers. Again, there may have been an easier way, and Fanuc should be able to help set that up.
All that being said, the NI-EIP module worked very nicely for me on a recent project. I wouldn't be surprised if it worked just as well talking to an EIP-equipped Fanuc robot.
HTH.
-Ryan
