If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
False 100ms pulse NI9401?
Hi everyone,
I am facing a very serious problem in my LabVIEW FPGA project, I am using the NI9401 DIO module and in a simple program in FPGA I provide all 8 channels FALSE in a loop, but when I access this FPGA VI from RT VI, when I exit the RT VI I have a unnecessary 100ms pulse on all 8 channels. I am attaching both VI,s images. PLEASE HELP IN THIS REGARDS!
This pulse actually makes a dangerous short circuit in my DC Converter.
With Best Regards,
azy
(3,233 Views)
Hi embedded,
why do you stop the FPGA VI at all?
Why not let it run and still output that "zero" to your DO pins?
You know the FPGA runs (or can run) independently for the RT system?
(3,197 Views)
Hi GerdW,
Thanks for the reply, now here is the problem here i am attaching my application FPGA VI, where i have to give inputs to FPGA in form of PWM parameters from HOST VI and also get sensors data from FPGA at the same time. and you notice i do work in FPGA in steps and when you next time start the application i have to reset the FPGA to follow the project sequence, if i hang the FPGA how can i get back without resetting FPGA???
I am attaching project RT and FPGA VI's.
Mod2 is NI9201
Mod3 is NI9215
Best Regards,
azy
(3,189 Views)
I agree with GerdW: don't stop the while loops in the FPGA. Put a case inside the loop that allows it to operate or not. For example:
(3,168 Views)
Hi embedded,
thanks for describing this undesired behaviour of glitches from the NI 9401.
There shouldn't be any impulses at all after the VI is stopped. This occurence is already reported and known by the NI R&D department.
Please use a workaround as Todd in previous post mentioned.
Kind regards,
rupido
NIG AE
(3,091 Views)
