Fall time measure at Labview
arielsl\ wrote:
I just want to determine what will be the dt at any acquisition of waveform that I'm gonna do with my scope.
dt is determined by the scope setup, the horizontal sec/div control.  You choose that value according to your needs.  After you acquire a waveform, dt is a component of the waveform and is determined by the scope setup.  you do not specify this value.  dt is the time between each data point acquisition in the waveform.
arielsl\ wrote:
I think that if you'll can do a VI that uses my scope and does a trigger acquisition with the regular subVI's that we both have it will be better, because that way  I will can use it with another scope except this one...
I know it should take long time, so I'll understand if you don't want to do it.
Thank you,
Ariel.
I'm afraid you will have to write that VI yourself.  I'm just a volunteer here.
- tbob
Inventor of the WORM Global
Message 21 of 21
(547 Views)
