Failure: "image.cpp", error 11602
I'm developing an application in LabView and with the Web publishing tool I can visualizethe results in Internet. The problem is that I open the explorer (Netscape or Internet Explorer) the following message appears in the screen: "Failure, "image.cpp", error 11602, please contact with NI" and the explorer is close... It's labview 6.1
(2,673 Views)
If your are using graphs on your front panel, be sure that no objects (control, indicator, cursor, ...) overlaps a graph.
I hope it will help you.
(2,673 Views)
having the same problem, only that it is in line 11374 or 865.
Tom
Tom Borton
Switzerland
(2,673 Views)
A good general starting point is www.ni.com/failure . Worth looking at
the specific tips (if any) for this error, and the general tips.
Mark
(2,673 Views)
Actually, I believe that the 11602 assert is a known issue with 6.1. It seems to be caused by leaving the popup "request control" menu in the browser open when the client gets disconnected from the server. Is this what you were doing when the error occurred? Do you know exactly what you did to cause it?
(2,673 Views)
